[geos-devel] Buffer on GEOMCOLLECTION and slight variations
Alex Trofast
alex.trofast at actian.com
Wed Feb 1 17:30:18 EST 2012
Greetings all,
The program pasted below will produce slightly different results on
different machines. It's calling BUFFER on a GEOMCOLLECTION.
On ArchLinux 64 bit with GCC 4.6.2 I get:
Buffer: POLYGON ((0.000 1.000, 0.000 1.000, 0.011 1.113, 0.019 1.195,
0.019 1.195, 0.019 1.195, 0.043 1.275, 0.076 1.383, 0.076 1.383, 0.076
1.383, 0.113 1.451, 0.169 1.556, 0.169 1.556, 0.169 1.556, 0.184 1.574,
0.293 1.707, 0.293 1.707, 0.293 1.707, 4.293 5.707, 4.444 5.831, 4.617
5.924, 4.805 5.981, 5.000 6.000, 5.195 5.981, 5.383 5.924, 5.556 5.831,
5.707 5.707, 5.831 5.556, 5.924 5.383, 5.981 5.195, 6.000 5.000, 5.981
4.805, 5.924 4.617, 5.831 4.444, 5.707 4.293, 1.707 0.293, 1.707 0.293,
1.707 0.293, 1.707 0.293, 1.700 0.287, 1.556 0.169, 1.556 0.169, 1.556
0.169, 1.474 0.125, 1.383 0.076, 1.383 0.076, 1.383 0.076, 1.293 0.049,
1.195 0.019, 1.195 0.019, 1.195 0.019, 1.094 0.009, 1.000 0.000, 1.000
0.000, 1.000 0.000, 0.874 0.012, 0.805 0.019, 0.805 0.019, 0.805 0.019,
0.680 0.057, 0.617 0.076, 0.617 0.076, 0.617 0.076, 0.494 0.142, 0.444
0.169, 0.444 0.169, 0.444 0.169, 0.366 0.233, 0.293 0.293, 0.293 0.293,
0.293 0.293, 0.218 0.384, 0.169 0.444, 0.169 0.444, 0.169 0.444, 0.128
0.521, 0.076 0.617, 0.076 0.617, 0.076 0.617, 0.048 0.710, 0.019 0.805,
0.019 0.805, 0.019 0.805, 0.011 0.890, 0.000 1.000, 0.000 1.000))
On OpenSUSE 10 64 bit, GCC 4.1.2
0.680 0.057, 0.617 0.076, 0.617 0.076, 0.617 0.076, 0.520 0.128, 0.444
0.169, 0.444 0.169, 0.444 0.169, 0.384 0.218, 0.293 0.293, 0.293 0.293,
The difference is in one coordinate pair:
0.494 0.142
vs
0.520 0.128
Is Buffer supposed to work on geomcollections such as the one below and
why would there be a slight discrepancy between results?
Thanks!
#include <geos_c.h>
#include <stdio.h>
#include <stdlib.h>
#define FALSE 0
#define TRUE 1
int main(int argc, char *argv[])
GEOSGeometry *geom, *buffer;
GEOSContextHandle_t handle;
GEOSWKTReader *reader;
GEOSWKTWriter *writer;
char *wkt;
handle = initGEOS_r(NULL, NULL);
reader = GEOSWKTReader_create_r(handle);
writer = GEOSWKTWriter_create_r(handle);
geom = GEOSWKTReader_read_r(handle, reader,
"GEOMETRYCOLLECTION(POINT(1 1), LINESTRING(1 1, 2 2, 4 4, 5 5))");
GEOSWKTWriter_setRoundingPrecision_r(handle, writer, 3);
GEOSWKTWriter_setTrim_r(handle, writer, FALSE);
buffer = GEOSBuffer_r(handle, geom, 1, 8);
wkt = GEOSWKTWriter_write_r(handle, writer, buffer);
printf("Buffer: %s\n", wkt);
return 0;
Alex
http://bit.ly/geodb
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20120201/fe8533c0/attachment.html
