[geos-devel] Re: [GEOS] #299:
geos::geom::CoordinateArraySequenceFactory unit
test failing on Bad Apple (was:
geos::geom::CoordinateArraySequenceFactory unit test failing)
geos-trac at osgeo.org
Fri Feb 3 05:42:18 EST 2012
#299: geos::geom::CoordinateArraySequenceFactory unit test failing on Bad Apple
Reporter: pramsey | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: GEOS Future
Component: Unit Tests | Version: svn-trunk
Severity: Unassigned | Resolution: wontfix
Keywords: mac,macosx,osx |
Changes (by strk):
* status: new => closed
* resolution: => wontfix
Comment:
After going through all comments about this I really believe it's not GEOS
business to work around Apple bugs.
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:28>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
