[geos-devel] Re: [GEOS] #299: geos::geom::CoordinateArraySequenceFactory unit test failing on Bad Apple
GEOS geos-trac at osgeo.org
Tue Feb 7 21:40:25 EST 2012
 Reporter:  pramsey         |        Owner:  geos-devel@…
     Type:  defect          |       Status:  reopened
 Priority:  major           |    Milestone:  GEOS Future
Component:  Unit Tests      |      Version:  svn-trunk
 Severity:  Unassigned      |   Resolution:
 Keywords:  mac,macosx,osx  |
Changes (by pramsey):
  * status:  closed => reopened
  * resolution:  wontfix =>
Comment:
 You don't have to block release, but you don't get to close it out. It's
 marked Future and when through some combination of Apple improvements or
 our own research we manage to close it, we will. As it stands, I can't
 regress geos, it's a bug :)
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:29>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
