[geos-devel] Re: [GEOS] #509: GEOS crashes on check in MingW GCC 4.6.2
GEOS geos-trac at osgeo.org
Wed Feb 8 20:13:51 EST 2012
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.3
Component:  Default     |     Version:  3.3.2
 Severity:  Unassigned  |    Keywords:
Comment(by dustymugs):
 For Windows 7 32-bit with the same MinGW, I get a different assertion
 failure
 group: capi::GEOSisValidDetail, test: test<3>
 problem: assertion failed
 tests summary: failures: 1 ok: 729
Ticket URL: <http://trac.osgeo.org/geos/ticket/509#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
