[geos-devel] Re: [GEOS] #299:
 geos::geom::CoordinateArraySequenceFactory unit
 test failing on Bad Apple
    geos-trac at osgeo.org
    Mon Feb 13 10:28:45 EST 2012
#299: geos::geom::CoordinateArraySequenceFactory unit test failing on Bad Apple
 Reporter:  pramsey         |        Owner:  geos-devel@…
     Type:  defect          |       Status:  reopened
 Priority:  major           |    Milestone:  GEOS Future
Component:  Unit Tests      |      Version:  svn-trunk
 Severity:  Unassigned      |   Resolution:
 Keywords:  mac,macosx,osx  |
Comment(by hobu):
 Additionally, how did you track this down?  I spent quite a while chasing
 this and mostly chased my tail...
 Do you have a fix for  #479 too, or did you compile this with clang?
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:32>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
