[geos-devel] Re: [GEOS] #513: Fix PHP 5.4 compatibility
geos-trac at osgeo.org
Mon Feb 27 10:57:27 EST 2012
Reporter: voxik | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.3
Component: Default | Version: 3.3.2
Severity: Unassigned | Keywords:
Comment(by strk):
Running "make check" should do the testing for you.
Ticket URL: <http://trac.osgeo.org/geos/ticket/513#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
