[geos-devel] Non Noded intersection bugs when performing Geometry
overlay
Martin Davis
mtnclimb at telus.net
Mon Feb 27 11:39:41 EST 2012
Hi, James.
This is definitely a GEOS issue.
What you're seeing, of course, is the usual issue of robustness problems
- likely due to "nearly coincident" linework during the second union.
This is where I'd expect to see problems, since if your input data is a
properly noded coverage, then the first union is simply dissolving
common line segments.
The only short-term recommendations is the usual one to reduce the
precision of the input geometry as much as possible (using I think
ST_SnapToGrid). This may still not solve the problem, however. The
ultimate solution is perform snap-rounding over the entire input set. I
don't think ST_Snap is doing this - AFAIK it's doing some
heuristic-based snapping only.
From the long series of ticket replies, it seems like C handling of
floating point might be causing some problems too, since GEOS seems to
be somewhat less robust than JTS in these various cases (although JTS
itself is not 100% robust either).
It would help if you can post the data, or a subset of it which exhibits
the problem. The problem area should be in the close neighbourhood of
the lines reported in the exception.
On 2/26/2012 10:25 PM, James Sewell wrote:
> Hello All,
> I'm never sure which list to fire these GEOS problems from PostGIS
> issues to, so I'll try them both this time.
> I'm using the following:
> PostgreSQL 9.1.2 on i686-pc-linux-gnu, compiled by gcc (GCC) 4.1.2
> 20080704 (Red Hat 4.1.2-44), 32-bit
> POSTGIS="2.0.0alpha7SVN" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
> September 2009" LIBXML="2.6.26" USE_STATS
> I have been closely following the updates to GEOS / PostGIS at the end
> of last year with regards to overlay routines. Since the advent of
> ST_UnaryUnion and the updates in the BinaryOp code as of r3552 I have
> been trying to get our overlay code working again. We currently do the
> following:
> ·Break left layer and right layer into smaller regions (both are
> multipolygons)
> ·For each region
> oUse ST_Snap to snap the left layer (which in this case is less
> accurate) to a collection of the right layer at 10E-8
> oDump the left and the right layers to linework and collect them to
> two geoms
> oPerform a ST_UnaryUnion on each layer, then collect them together
> oPerform a ST_UnaryUnion on the collection (I found using this two
> tiered Union approach sometimes resolved nodding errors, obviously at
> the cost of speed though). If I get a non-noded intersection problem
> it is here 100% of the time.
> oPolygonize the output
> oPerform overlay map to pull through gids from original left and right
> layers
> At one point I did translate to the origin before any Union
> operations, but this broke down as the linework got more complex
> (which unfortunately happens every month as new polygons are added).
> At the moment the problem I face is the same as my old problem (when
> using ST_Union, see http://trac.osgeo.org/geos/ticket/392). When
> performing the second ST_UnaryUnion of the collected left and right
> lineworks (which are valid) I get the following:
> GEOSUnion: TopologyException: found non-noded intersection between
> LINESTRING (149.169 -37.739, 149.169 -37.7391) and LINESTRING (149.169
> -37.7391, 149.169 -37.739) at 149.16916209449002 -37.739087184984776
> This year I've been familiarising myself with the code and reading
> through all the old posts I can find which apply to this.
> I just wanted to throw this list post out there to see what others had
> to say about this issue. It seems to have been round for a while now,
> and from what I can tell it's not an easy fix.
> Yum install
> Is it likely to be a precision issue? I am currently upgrading my GCC
> version so I can try this http://trac.osgeo.org/geos/ticket/504, does
> anyone have any thoughts on if that might help?
> Or is the issue more likely to be as described here?
> http://trac.osgeo.org/geos/ticket/459
> Sorry for the long post, just hoping to get some discussion going. I
> will try to post a fresh testcase which causes the error tomorrow.
> Cheers,
> James Sewell
> Solutions Architect
> LISAsoft
> *Ph: *+61 3 8680 3250 *Fax: *+61 3 8680 3299
> Level 9, 601 Bourke St, Melbourne Vic 3000
> http://www.lisasoft.com <http://www.lisasoft.com/>
> The contents of this email are confidential and may be subject to
> legal or professional privilege and copyright. No representation is
> made that this email is free of viruses or other defects. If you have
> received this communication in error, you may not copy or distribute
> any part of it or otherwise disclose its contents to anyone. Please
> advise the sender of your incorrect receipt of this correspondence.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2012.0.1913 / Virus Database: 2114/4833 - Release Date: 02/26/12
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20120227/d3960b86/attachment.html
