[geos-devel] Re: [GEOS] #513: Fix PHP 5.4 compatibility
geos-trac at osgeo.org
Mon Feb 27 15:41:03 EST 2012
Reporter: voxik | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.3
Component: Default | Version: 3.3.2
Severity: Unassigned | Keywords:
Comment(by voxik):
Actually, checking the build log [1], it seems that some tests were
executed, so hopefully it works ;)
[1]
http://kojipkgs.fedoraproject.org/packages/geos/3.3.2/2.fc17/data/logs/x86_64/build.log
Ticket URL: <http://trac.osgeo.org/geos/ticket/513#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
