[geos-devel] [GEOS] #568: mingw64 chain compiling win32 regress failure
geos-trac at osgeo.org
Tue Jul 3 07:41:28 PDT 2012
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
The good news is I get 3 fewer failures compiling my 32-bit under the ming
64 chain. The bad news I still get a failure. See attached file. This is
using gcc 4.5.4 (I suspect I probably still have issues with 4.6+)
Ticket URL: <http://trac.osgeo.org/geos/ticket/568>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
