[geos-devel] [GEOS] #570: Add Z support in delaunay triangulation
GEOS geos-trac at osgeo.org
Wed Jul 18 01:17:51 PDT 2012
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 I didn't test the patch but I've the impression it would always add a Z ?
 I think the output should only have a Z when the input does.
 Also, could you add tests for this ? Thanks !
Ticket URL: <http://trac.osgeo.org/geos/ticket/570#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
