[geos-devel] Error: Build GEOS 3.3.5 on Windows
taibc taibc_coltech at yahoo.com
Mon Jul 23 03:44:20 PDT 2012
Dear Mateusz,
After building GEOS, I copied file geos.dll into my project (using Visual Studio 210, C++).
But, when I used the method: Geometry::Within(OGRGeometry* po) ", I got the error: "GEOS support not enable"
Do you know how to fix it ?
Thanks and regards,
Tai
 From: Mateusz Loskot [via OSGeo.org] <ml-node+s1560n4990018h77 at n6.nabble.com>
To: taibc <taibc_coltech at yahoo.com>
Sent: Monday, July 23, 2012 5:08 PM
Subject: Re: Error: Build GEOS 3.3.5 on Windows
On 23 July 2012 08:07, taibc <[hidden email]> wrote:
> Hi friends,
>  I am trying to build GEOS (Version 3.3.5) on Window 7 by using Visual
> Studio Command Prompt (2010) , with the statement: "nmake -f makefile.vc
> MSVC_VER=1600". But I got the bellow error:
Check again the updated version of building instructions:
http://trac.osgeo.org/geos/wiki/BuildingOnWindowsWithNMake
You do need to run autogen.bat first.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
geos-devel mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/geos-devel
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/Error-Build-GEOS-3-3-5-on-Windows-tp4989974p4990018.html
To unsubscribe from Error: Build GEOS 3.3.5 on Windows, click here.
NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-Build-GEOS-3-3-5-on-Windows-tp4989974p4990027.html
Sent from the GEOS Developers mailing list archive at Nabble.com.
