[geos-devel] compile on aix
Emre Ersin emree at mobiliz.com.tr
Mon Jun 4 09:31:38 PDT 2012
Hello,
I am trying to compile GEOS 3.3.4 (I have also tried older versions) on
AIX 7.1 platform. I do not have any admin rights on that server so I
have to make all setup things in usermode by defining LIBPATH (other
than opt/freeware) and PATHs.
During make  something gives segmentaion fault;
./configure --prefix=/home/users/emre --disable-inline
make
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../../include
-I../../../include/geos -I../../../include -pedantic -Wall -ansi
-Wno-long-long -ffloat-store -g -O2 -MT IndexedPointInAreaLocator.lo -MD
-MP -MF .deps/IndexedPointInAreaLocator.Tpo -c
IndexedPointInAreaLocator.cpp  -DPIC -o
.libs/IndexedPointInAreaLocator.o
g++: internal compiler error: Segmentation fault (program as)
(It says assembly command "as" gives the fault but I am not sure)
geos-3.3.4:>as -version
as V7.1
geos-3.3.4:>g++ -v
Using built-in specs.
COLLECT_GCC=g++
COLLECT_LTO_WRAPPER=/home/users/emre/bin/../libexec/gcc/powerpc-ibm-aix7
.1.0.0/4.6.3/lto-wrapper
Target: powerpc-ibm-aix7.1.0.0
Configured with: ../gcc-4.6.3/configure --with-as=/usr/bin/as
--with-ld=/usr/bin/ld --enable-languages=c,c++,fortran
--prefix=/opt/freeware --mandir=/opt/freeware/man
--infodir=/opt/freeware/info --enable-threads
--enable-version-specific-runtime-libs --disable-nls
--enable-decimal-float=dpd --host=powerpc-ibm-aix7.1.0.0
Thread model: aix
gcc version 4.6.3 (GCC)
Does anyone have any clue?
By the way; Postgresql 9.0.3 has been compiled successfully by using
this configuration. And it is working now.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20120604/33dc90a7/attachment.html>
