[geos-devel] [GEOS] #487: Port Delaunay Triangulation API from	JTS
    geos-trac at osgeo.org
    Tue Jun  5 14:06:18 PDT 2012
 Reporter:  strk         |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  3.4.0
Component:  Default      |     Version:  svn-trunk
 Severity:  Unassigned   |    Keywords:
Comment(by strk):
 A couple of things I noticed:
  1. You assigned the copyright to Refractions Research in 2006
  2. The "Last port" line should contain the SVN revision id of the JTS
 file you ported
 didn't look at the actual code yet (will do as soon as I find a few hours)
 Thanks for contributing, btw :)
Ticket URL: <http://trac.osgeo.org/geos/ticket/487#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
