[geos-devel] [GEOS] #557: Build error on Mac
geos-trac at osgeo.org
Thu Jun 14 13:34:35 PDT 2012
Reporter: dburken | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.5
Component: Default | Version: 3.3.4
Severity: Unassigned | Keywords:
Svn revision 3673
Darwin Kernel Version 11.4.0
gcc version 4.2.1
In file included from /work/osgeo/geos/geos-svn/capi/geos_c.cpp:48:
/work/osgeo/geos/geos-svn/capi/geos_c.h:1196:9: warning: struct
'WKTReader' was previously declared as a class
[-Wmismatched-tags]
typedef struct GEOSWKTReader_t GEOSWKTReader;
/work/osgeo/geos/geos-svn/include/geos/io/WKTReader.h:58:16: note:
previous use is here
class GEOS_DLL WKTReader {
/work/osgeo/geos/geos-svn/capi/geos_c.h:1196:9: note: did you mean class
here?
class
/work/osgeo/geos/geos-svn/capi/geos_c.h:1197:9: warning: struct
'WKTWriter' was previously declared as a class
[-Wmismatched-tags]
typedef struct GEOSWKTWriter_t GEOSWKTWriter;
/work/osgeo/geos/geos-svn/include/geos/io/WKTWriter.h:79:16: note:
class GEOS_DLL WKTWriter {
/work/osgeo/geos/geos-svn/capi/geos_c.h:1197:9: note: did you mean class
here?
class
/work/osgeo/geos/geos-svn/capi/geos_c.h:1198:9: warning: struct
'WKBReader' was previously declared as a class
[-Wmismatched-tags]
typedef struct GEOSWKBReader_t GEOSWKBReader;
/work/osgeo/geos/geos-svn/include/geos/io/WKBReader.h:79:16: note:
class GEOS_DLL WKBReader {
/work/osgeo/geos/geos-svn/capi/geos_c.h:1198:9: note: did you mean class
here?
class
/work/osgeo/geos/geos-svn/capi/geos_c.h:1199:9: warning: struct
'WKBWriter' was previously declared as a class
[-Wmismatched-tags]
typedef struct GEOSWKBWriter_t GEOSWKBWriter;
/work/osgeo/geos/geos-svn/include/geos/io/WKBWriter.h:72:16: note:
class GEOS_DLL WKBWriter {
/work/osgeo/geos/geos-svn/capi/geos_c.h:1199:9: note: did you mean class
here?
class
/work/osgeo/geos/geos-svn/capi/geos_c.cpp:118:1: error: unknown type name
'GEOSInterruptCallback'; did you mean
'GEOSQueryCallback'?
GEOSInterruptCallback*
GEOSQueryCallback
/work/osgeo/geos/geos-svn/capi/geos_c.h:138:16: note: 'GEOSQueryCallback'
declared here
typedef void (*GEOSQueryCallback)(void *item, void *userdata);
/work/osgeo/geos/geos-svn/capi/geos_c.cpp:119:32: error: use of undeclared
identifier 'GEOSInterruptCallback'; did you mean
GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb)
/work/osgeo/geos/geos-svn/capi/geos_c.cpp:119:55: error: use of undeclared
identifier 'cb'
/work/osgeo/geos/geos-svn/capi/geos_c.cpp:119:58: error: expected ';'
after top level declarator
Ticket URL: <http://trac.osgeo.org/geos/ticket/557>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
