[geos-devel] [GEOS] #535: GeometryComponentFilter::filter_ro: Assertion `0' failed
geos-trac at osgeo.org
Fri Jun 22 04:34:57 PDT 2012
Reporter: aaronharris | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.5
Component: Default | Version: 3.3.3
Severity: Unassigned | Keywords:
Comment(by strk):
I wonder if this is related to the GEOS_INLINE switch.
Did you set custom CXX flags while building ?
Does the problem still occur with current 3.3 branch ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/535#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
