[geos-devel] [GEOS] #557: Build error on Mac
GEOS geos-trac at osgeo.org
Fri Jun 22 05:39:37 PDT 2012
 Reporter:  dburken     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.5
Component:  Default     |     Version:  3.3.4
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Did you run ./configure again after updating ?
 It would explain your problem with GEOSInterruptCallback.
Ticket URL: <http://trac.osgeo.org/geos/ticket/557#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
