[geos-devel] [GEOS] #557: Build error on Mac
geos-trac at osgeo.org
Fri Jun 22 05:56:20 PDT 2012
Reporter: dburken | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.5
Component: Default | Version: 3.3.4
Severity: Unassigned | Keywords:
Comment(by strk):
Oh.. cmake.. that build kind is slower at being maintained. Worth a
separate ticket, do you mind ?
The thing is that GEOSInterruptCallback is typedefe'd in geos_c.h which is
generated by geos_c.h.in at ./configure time. No idea what generates it
with CMake (if any).
All I know is that CMAKE is not the official build system. What prevents
you to use the automake based build on mac OSX ? Is it not a POSIX system
? Does it intentionally try to be different ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/557#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
