[geos-devel] [GEOS] #557: Build error on Mac
geos-trac at osgeo.org
Fri Jun 22 06:37:08 PDT 2012
Reporter: dburken | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.5
Component: Default | Version: 3.3.4
Severity: Unassigned | Keywords:
Comment(by kyngchaos):
I'm not sure, but I think the framework build is only in Cmake.
And as Howard says, clang is the way to go. Add this to cmake configure:
-D CMAKE_CXX_COMPILER="/usr/bin/clang++" \
-D CMAKE_C_COMPILER="/usr/bin/clang" \
It looks like cmake doesn't have a target to create geos_c.h, so this
needs to be fixed for compiling from svn source.
Ticket URL: <http://trac.osgeo.org/geos/ticket/557#comment:9>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
