[geos-devel] [GEOS] #559: EMPTY Centroid of tiny triangular polygon
geos-trac at osgeo.org
Fri Jun 22 07:46:22 PDT 2012
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.5
Component: Default | Version: 3.3.4
Severity: Unassigned | Keywords:
Comment(by strk):
I found an unported handling for this case in JTS (degenerate area).
Trying that out now.
Mind you: an empty polygon seems still unhandled by JTS.
Ticket URL: <http://trac.osgeo.org/geos/ticket/559#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
