[geos-devel] [GEOS] #517: GEOS Intersection() error w/ test case.
Martin Davis
mtnclimb at telus.net
Fri Jun 22 10:39:59 PDT 2012
You might want to try removing the FIXED(0) precision model from the
test case.
I can reproduce this error in JTS. Not sure yet what the problem is,
though.
> Reporter: andrepl | Owner: geos-devel@…
> Type: defect | Status: new
> Priority: major | Milestone: 3.3.6
> Component: Default | Version: 3.3.2
> Severity: Unassigned | Keywords:
> Changes (by strk):
> * milestone: 3.3.5 => 3.3.6
> Comment:
> andrepl: I need help to reproduce this if you want it fixed. At least the
> crash error message. Also, was it the 3.3.3 version and not trunk ? I'll
> close after 1 week if there's no feedback here.
