[geos-devel] [GEOS] #515: mingw64 make check returns #IND
GEOS geos-trac at osgeo.org
Mon Mar 5 11:18:29 EST 2012
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  trivial     |   Milestone:  3.3.3
Component:  Default     |     Version:  3.3.2
 Severity:  Unassigned  |    Keywords:
 On my mingw64 chain.  Make check tests pass except for 1
 ---> group: capi::GEOSisValidDetail, test: test<3>
      problem: assertion failed
      failed assertion: "Values are not equal: expected 'POINT (NAN -5)'
 actual '
 POINT (-1.#IND -5)'"
 strk says its a harmless failure and just anotehr presentation of NAN.
Ticket URL: <http://trac.osgeo.org/geos/ticket/515>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
