[geos-devel] Re: [GEOS] #524: IntersectionMatrix of a line with itself has NO boundary intersection [JTS fails too]
GEOS geos-trac at osgeo.org
Fri Mar 30 09:52:48 EDT 2012
fails too]
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.3
Component:  Default     |     Version:  3.3.2
 Severity:  Unassigned  |    Keywords:  jtsfail
Comment(by strk):
 Mind you: the attached testcase works with JTS but has an unsupported
 format in GEOS.
 XMLTester is to be fixed to support it.
Ticket URL: <http://trac.osgeo.org/geos/ticket/524#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
