[geos-devel] Re: [GEOS] #525: Polygonizer fails to polygonize
simple input
geos-trac at osgeo.org
Sat Mar 31 12:31:52 EDT 2012
#525: Polygonizer fails to polygonize simple input
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.3.3
Component: Default | Version: 3.3.2
Severity: Unassigned | Resolution: invalid
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => invalid
Comment:
Alright my WKT wasn't correctly noded.
The nodes are (4,0), (4,3) and (6,0).
Passing correctly noded input gives the correct answer, which is the
"A"-looking polygon,
the polygon covering the southbound triangle hole and the polygon covering
the small northbound triangle at the bottom.
GEOMETRYCOLLECTION(POLYGON((4 0,0 0,5 10,10 0,6 0,5 3,4 0),(5 3,6 6,4 6,5
3)),POLYGON((4 0,5 3,6 0,4 0)),POLYGON((5 3,4 6,6 6,5 3)))
Ticket URL: <http://trac.osgeo.org/geos/ticket/525#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
