[geos-devel] [GEOS] #534: Cross compile trunk for android
geos-trac at osgeo.org
Thu May 3 07:14:24 EDT 2012
Reporter: mbernasocchi | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.4
Component: Default | Version: svn-trunk
Severity: Significant | Keywords: android
Basically PGAC_TYPE_64BIT_INT([int64_t])
fails to work on configure.ac line 220
PGAC_TYPE_64BIT_INT is implemented in acsite.m4
when cross compiling using the android NDK r6b (4.4.3) and make check
fails.
Ticket URL: <http://trac.osgeo.org/geos/ticket/534>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
