[geos-devel] Re: [GEOS] #534: Cross compile trunk for android
geos-trac at osgeo.org
Thu May 3 07:22:49 EDT 2012
Reporter: mbernasocchi | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.4
Component: Default | Version: svn-trunk
Severity: Significant | Keywords: android
Comment(by mbernasocchi):
and this is the last part of the make check:
/bin/bash ../../libtool --tag=CXX --mode=compile arm-linux-
androideabi-g++ -DHAVE_CONFIG_H -I. -I../../../src/geom -I../../include
-I../../include/geos -I../../../include -DGEOS_INLINE -pedantic -Wall
-ansi -Wno-long-long -ffloat-store -DANDROID=ON -Wno-psabi -O2 -mthumb
-std=gnu++0x -MT LineSegment.lo -MD -MP -MF .deps/LineSegment.Tpo -c -o
LineSegment.lo ../../../src/geom/LineSegment.cpp
libtool: compile: arm-linux-androideabi-g++ -DHAVE_CONFIG_H -I.
-I../../../src/geom -I../../include -I../../include/geos
-I../../../include -DGEOS_INLINE -pedantic -Wall -ansi -Wno-long-long
-ffloat-store -DANDROID=ON -Wno-psabi -O2 -mthumb -std=gnu++0x -MT
../../../src/geom/LineSegment.cpp -fPIC -DPIC -o .libs/LineSegment.o
In file included from ../../../include/geos/geom/Coordinate.h:19,
from ../../../include/geos/geom/LineSegment.h:25,
from ../../../src/geom/LineSegment.cpp:21:
../../include/geos/platform.h:71:5: warning: #warning is a GCC extension
../../include/geos/platform.h:71:5: warning: #warning "Could not find
64bit integer definition!"
In file included from ../../../include/geos/geom/Coordinate.h:160,
../../../include/geos/geom/Coordinate.inl: In static member function
'static int geos::geom::Coordinate::hashCode(double)':
../../../include/geos/geom/Coordinate.inl:108: warning: right shift count
>= width of type
In file included from ../../../src/geom/LineSegment.cpp:25:
../../../include/geos/geom/GeometryFactory.h: At global scope:
../../../include/geos/geom/GeometryFactory.h:209: warning: 'auto_ptr' is
deprecated (declared at
/home/marco/dev/necessitas/android-9-standalonetoolchain/bin/../lib/gcc
/arm-linux-androideabi/4.4.3/../../../../arm-linux-
androideabi/include/c++/4.4.3/backward/auto_ptr.h:86)
../../../include/geos/geom/GeometryFactory.h:258: warning: 'auto_ptr' is
../../../include/geos/geom/GeometryFactory.h:306: warning: 'auto_ptr' is
../../../src/geom/LineSegment.cpp -o LineSegment.o >/dev/null 2>&1
mv -f .deps/LineSegment.Tpo .deps/LineSegment.Plo
-std=gnu++0x -MT LineString.lo -MD -MP -MF .deps/LineString.Tpo -c -o
LineString.lo ../../../src/geom/LineString.cpp
../../../src/geom/LineString.cpp -fPIC -DPIC -o .libs/LineString.o
from ../../../src/geom/LineString.cpp:23:
>= width of type
In file included from ../../../src/geom/LineString.cpp:31:
In file included from ../../../src/geom/LineString.cpp:33:
../../../include/geos/geom/Point.h:167: warning: 'auto_ptr' is deprecated
(declared at
../../../src/geom/LineString.cpp:96: warning: 'auto_ptr' is deprecated
(declared at
../../../src/geom/LineString.cpp: In member function 'virtual
std::auto_ptr<geos::geom::Envelope>
geos::geom::LineString::computeEnvelopeInternal() const':
../../../src/geom/LineString.cpp:250: internal compiler error:
Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
make[3]: *** [LineString.lo] Error 1
make[3]: Leaving directory `/home/marco/dev/qgis-android/src/geos-svn
/build-armeabi/src/geom'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/home/marco/dev/qgis-android/src/geos-svn
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/home/marco/dev/qgis-android/src/geos-svn
/build-armeabi/src'
make: *** [check-recursive] Error 1
Ticket URL: <http://trac.osgeo.org/geos/ticket/534#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
