[geos-devel] [GEOS] #549: Solaris 9 - fully qualified binaryop() calls needed
GEOS geos-trac at osgeo.org
Wed May 16 15:31:42 PDT 2012
 Reporter:  tmitchell   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.4
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
 When building (3.3.2) on Solaris 9, we were getting...
 CC: Warning: Option -pedantic passed to ld, if ld is invoked, ignored
 otherwise
 "../include/geos/index/strtree/AbstractSTRtree.h", line 198: Warning:
 nodes hides geos::index::strtree::AbstractSTRtree::nodes.
 "../include/geos/algorithm/distance/DiscreteHausdorffDistance.h", line
 227: Warning: g0 hides
 geos::algorithm::distance::DiscreteHausdorffDistance::g0.
 227: Warning: g1 hides
 geos::algorithm::distance::DiscreteHausdorffDistance::g1.
 "geos_ts_c.cpp", line 1608: Error: BinaryOp is not defined.
 "geos_ts_c.cpp", line 1609: Error: extern "C"
 std::auto_ptr<geos::geom::Geometry>(*)() is not a structure type.
 "geos_ts_c.cpp", line 1853: Error: BinaryOp is not defined.
 "geos_ts_c.cpp", line 1854: Error: extern "C"
 4 Error(s) and 3 Warning(s) detected.
 *** Error code 1
 make: Fatal error: Command failed for target `libgeos_c_la-geos_ts_c.lo'
 We made a tweak to {{{capi/geos_ts_c.cpp}}}, making fully qualified
 {{{BinaryOp()}}} calls with {{{geos::geom::BinaryOp()}}}.
 This resolved compilation errors on Solaris 9.  Hope that helps future
 releases.
Ticket URL: <http://trac.osgeo.org/geos/ticket/549>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
