[geos-devel] [GEOS] #551: Segfault in Distance functions
geos-trac at osgeo.org
Sun May 20 06:24:55 PDT 2012
Reporter: pramsey | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.4
Component: Default | Version: 3.3.3
Severity: Unassigned | Keywords:
In Centos 6, 64bit,
./XMLTester ./tests/general/TestWithinDistance.xml
also in the TestDistance.xml function. Backtrace:
Program received signal SIGABRT, Aborted.
0x00110424 in __kernel_vsyscall ()
Missing separate debuginfos, use: debuginfo-install
glibc-2.12-1.47.el6_2.9.i686 libgcc-4.4.6-3.el6.i686
libstdc++-4.4.6-3.el6.i686
(gdb) bt
#0 0x00110424 in __kernel_vsyscall ()
#1 0x00492af1 in raise () from /lib/libc.so.6
#2 0x004943ca in abort () from /lib/libc.so.6
#3 0x0048bdcb in __assert_fail_base () from /lib/libc.so.6
#4 0x0048be86 in __assert_fail () from /lib/libc.so.6
#5 0x0033637d in
geos::geom::GeometryComponentFilter::filter_ro(geos::geom::Geometry
const*) ()
from
/home/pramsey/suite/installer/linux/rpm/rpmbuild/BUILD/geos-3.3.3/src/.libs/libgeos-3.3.3.so
#6 0x003409ef in
geos::geom::Point::apply_ro(geos::geom::GeometryComponentFilter*) const ()
from
#7 0x003a4a33 in
geos::operation::distance::DistanceOp::computeFacetDistance() ()
from
#8 0x003a4e0b in
geos::operation::distance::DistanceOp::computeMinDistance() ()
from
#9 0x003a50f1 in geos::operation::distance::DistanceOp::distance() ()
from
#10 0x003a5449 in
geos::operation::distance::DistanceOp::distance(geos::geom::Geometry
const*, geos::geom::Geometry const*) () from
#11 0x0032fa45 in geos::geom::Geometry::distance(geos::geom::Geometry
const*) const ()
from
#12 0x00330511 in
geos::geom::Geometry::isWithinDistance(geos::geom::Geometry const*,
double) const ()
from
#13 0x0805250e in XMLTester::parseTest (this=0xbffff10c, node=0x806b308)
at XMLTester.cpp:1153
#14 0x0805409c in XMLTester::parseCase (this=0xbffff10c, node=0x806afc0)
at XMLTester.cpp:644
#15 0x080546bc in XMLTester::parseRun (this=0xbffff10c, node=0x806ad60) at
XMLTester.cpp:449
#16 0x08054c4c in XMLTester::run (this=0xbffff10c,
source="./tests/general/TestWithinDistance.xml") at XMLTester.cpp:399
#17 0x080550f5 in main (argC=2, argV=0xbffff274) at XMLTester.cpp:1507
Ticket URL: <http://trac.osgeo.org/geos/ticket/551>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
