[geos-devel] [GEOS] #535: GeometryComponentFilter::filter_ro: Assertion `0' failed (was: error running make check)
GEOS geos-trac at osgeo.org
Mon May 28 05:51:02 PDT 2012
 Reporter:  aaronharris  |       Owner:  geos-devel@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  3.3.4
Component:  Default      |     Version:  3.3.3
 Severity:  Unassigned   |    Keywords:
Comment(by strk):
 For the record: this shouldn't happen because the derivate class version
 of the method should be invoked.
Ticket URL: <http://trac.osgeo.org/geos/ticket/535#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
