[geos-devel] [GEOS] #515: mingw64 make check returns #IND
GEOS geos-trac at osgeo.org
Mon May 28 05:58:53 PDT 2012
 Reporter:  robe        |        Owner:  geos-devel@…
     Type:  defect      |       Status:  closed
 Priority:  trivial     |    Milestone:  3.3.4
Component:  Default     |      Version:  3.3.2
 Severity:  Unassigned  |   Resolution:  wontfix
 Keywords:              |
Changes (by strk):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 I'll close this bug as won't fix. I don't personally care about windows so
 unless someone very motivated gives feedback there's no much to do about
 it.
Ticket URL: <http://trac.osgeo.org/geos/ticket/515#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
