[geos-devel] [GEOS] #509: GEOS crashes on check in MingW GCC 4.6.2
geos-trac at osgeo.org
Tue May 29 23:20:18 PDT 2012
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.3.4
Component: Default | Version: 3.3.3
Severity: Unassigned | Resolution: wontfix
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => wontfix
Comment:
This ticket is actually a bit of a mess, a mix of different errors. Latest
comments are about the NaN handling but original one is about a topology
exception.
Seems cleaner to just close it and let reporters reopen if they still have
issues.
Ticket URL: <http://trac.osgeo.org/geos/ticket/509#comment:8>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
