[geos-devel] Closing up 3.3.4
Sandro Santilli strk at keybit.net
Wed May 30 00:08:11 PDT 2012
3.3.4 tagged in SVN (r3660).
In an hour we'll see if the git sync script will figure out.
NOTE: I had to switch to SVN to release for:
 - Generating the ChangeLog
 - Tagging
--strk;
On Tue, May 29, 2012 at 09:52:54PM +0200, Paul Ramsey wrote:
> Lots done, punt those issues forward and I am happy to push out a tarball.
> P.
> On Mon, May 28, 2012 at 4:17 PM, Sandro Santilli <strk at keybit.net> wrote:
> > I'd like to cut a 3.3.4 release, to go along with upcoming PostGIS 2.0.1.
> > After triaging there are 4 tickets left for the milestone:
> > http://trac.osgeo.org/geos/query?status=assigned&status=new&status=reopened&milestone=3.3.4
> > Non would be blocker in my opinion, do you think any is ?
> > Any other issue you think should be dealt with before shipping 3.3.4 ?
> > Changes since 3.3.3:
> > - Bug fixes / improvements
> >    - Do not abort on NaN overlay input (#530)
> >    - Reduce CommonBitsRemover harmful effects during overlay op (#527)
> >    - Better cross-compiler support (#534)
> >    - Enable overlay ops short-circuits (#542)
> >    - Envelope-based short-circuit for symDifference (#543)
> >    - Fix support for PHP 5.4 (#513)
> >    - Fix TopologyPreservingSimplifier invalid output on closed line (#508)
> >    - Reduce calls to ptNotInList, greatly speeding up Polygonizer (#545)
> > -strk;
