[geos-devel] [GEOS] #585: mingw64 trunk make check fail on badthreadtest
geos-trac at osgeo.org
Mon Oct 1 07:50:49 PDT 2012
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: reopened
Priority: minor | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution:
Keywords: |
Comment(by robe):
That didn't work. I had to rename both badthreadtest and threadtest and
change the .am file, but just got different error:
x86_64-w64-mingw32-g++ -DHAVE_CONFIG_H -I. -I../../include
-I../../include/geos -I../../include -I../../tests/unit/tut -I../../capi
-DGEOS_INLINE -pedantic -Wall -ansi -Wno-long-long -ffloat-store -g -O2
-MT threadtest.o -MD -MP -MF .deps/threadtest.Tpo -c -o threadtest.o
threadtest.cc
In file included from
c:\ming64\mingw64\bin\../lib/gcc/x86_64-w64-mingw32/4.5.4/../../../../x86_64-w64-mingw32/include/unistd.h:10:0,
from threadtest.cc:19:
../../include/geos/io.h:61:2: warning: #warning *** DEPRECATED: You are
using deprecated header io.h. Please, update your sources according to new
layout of GEOS headers and namespaces
threadtest.cc:23:21: fatal error: pthread.h: No such file or directory
compilation terminated.
make[4]: *** [threadtest.o] Error 1
make[4]: Leaving directory `/c/jenkins/geos/branches/3.4/tests/thread'
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/c/jenkins/geos/branches/3.4/tests/thread'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/c/jenkins/geos/branches/3.4/tests'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/c/jenkins/geos/branches/3.4'
make: *** [check] Error 2
Ticket URL: <http://trac.osgeo.org/geos/ticket/585#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
