[geos-devel] [GEOS] #585: mingw64 trunk make check fail on badthreadtest
GEOS geos-trac at osgeo.org
Mon Oct 1 09:52:40 PDT 2012
 Reporter:  robe        |        Owner:  geos-devel@…
     Type:  defect      |       Status:  reopened
 Priority:  minor       |    Milestone:  3.4.0
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment(by strk):
 I'm looking again at the original report and can't understand this
 message:
 In file included from
 c:\ming64\mingw64\bin\../lib/gcc/x86_64-w64-mingw32/4.5.4/../../../../x86_64-w64-mingw32/include/unistd.h:10:0,
                  from threadtest.c:19:
 ../../include/geos/io.h:19:11: error: expected '=', ',', ';', 'asm' or
 '__attribute__' before 'geos'
 Where is {{{
 }}} ? And what is including io.h ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/585#comment:9>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
