[geos-devel] [GEOS] #585: mingw64 trunk make check fail on badthreadtest
GEOS geos-trac at osgeo.org
Mon Oct 1 11:08:54 PDT 2012
 Reporter:  robe        |        Owner:  geos-devel@…
     Type:  defect      |       Status:  reopened
 Priority:  minor       |    Milestone:  3.4.0
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment(by strk):
 I think we could rename io.h to geosIO.h, btw. I dubt anyone is using that
 header, and if it does it's known that C++ API is prone to changes.
 Anyway a more elegant solution only affecting DEFAULT_INCLUDE would be
 much better IMHO
Ticket URL: <http://trac.osgeo.org/geos/ticket/585#comment:14>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
