[geos-devel] [GEOS] #580: Contains(Polygon, Point) return False instead of True
geos-trac at osgeo.org
Sun Sep 2 23:31:41 PDT 2012
Reporter: skurlat | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.6
Component: Default | Version: 3.3.4
Severity: Unassigned | Keywords:
Changes (by strk):
* milestone: 3.3.5 => 3.3.6
Comment:
Did you check the polygon for validity ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/580#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
