[geos-devel] [GEOS] #580: Contains(Polygon, Point) return False instead of True
geos-trac at osgeo.org
Mon Sep 3 10:43:12 PDT 2012
Reporter: skurlat | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.6
Component: Default | Version: 3.3.4
Severity: Unassigned | Keywords:
Comment(by pramsey):
I did, ST_IsValid says it's valid. And the PostGIS ST_Contains returns
true, which would be calculated in the internal liblwgeom code line
(point-in-poly), not in GEOS.
Ticket URL: <http://trac.osgeo.org/geos/ticket/580#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
