[geos-devel] [GEOS] #587: Memory leak in geos trunk
geos-trac at osgeo.org
Mon Sep 10 03:09:10 PDT 2012
Reporter: bradh | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
I'm working on an application that uses GEOS indirectly (via SpatiaLite).
In earlier versions of GEOS, it was valgrind-clean (no memory leaks). With
trunk, I see two minor leaks, both of which come from initGEOS().
==7181== 16 bytes in 1 blocks are still reachable in loss record 1 of 2
==7181== at 0x4C28B35: operator new(unsigned long)
(vg_replace_malloc.c:261)
==7181== by 0x6C7133E: geos::geom::GeometryFactory::GeometryFactory()
(GeometryFactory.cpp:86)
==7181== by 0x6C7400E:
geos::geom::GeometryFactory::getDefaultInstance()
(GeometryFactory.cpp:728)
==7181== by 0x6874B5C: initGEOS_r (geos_ts_c.cpp:206)
==7181== by 0x6872ACD: initGEOS (geos_c.cpp:98)
==7181== by 0x51B8BFA: spatialite_init (spatialite.c:21708)
==7181== by 0x40092C: main (check_point_to_tile_wrong_arg_type.c:61)
==7181==
==7181== 32 bytes in 1 blocks are still reachable in loss record 2 of 2
==7181== by 0x6C74003:
Note that there is a call to finishGEOS() which cleans up most, but not
all, of the memory leak.
I did try investigating this, and deleting the defInstance did fix the
memory leak, but it completely broke on threaded applications.
Ticket URL: <http://trac.osgeo.org/geos/ticket/587>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
