[geos-devel] [GEOS] #588: valid polygon when cw, not valid when ccw
geos-trac at osgeo.org
Wed Sep 12 03:04:03 PDT 2012
Reporter: olivier80 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.6
Component: Default | Version: 3.3.5
Severity: Unassigned | Keywords:
Comment(by strk):
Ouch! Confirmed, also using st_reverse.
I'm with 3.4.0dev here, are you on 3.3.5 ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/588#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
