[geos-devel] [GEOS] #594: geos turns 'POLYGON EMPTY' into 'POLYGON(EMPTY)'
geos-trac at osgeo.org
Tue Sep 25 18:49:31 PDT 2012
Reporter: cdestigter | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.6
Component: Default | Version: 3.3.3
Severity: Unassigned | Keywords:
I wouldn't mind except that in postgis, ST_IsEmpty('POLYGON(EMPTY)') ==>
False.
Using the geodjango bindings:
>>> from django.contrib.gis import geos
>>> g = geos.GEOSGeometry('POLYGON EMPTY')
>>> print g.wkt, g.hex
'01030000000100000000000000'
>>> g = geos.GEOSGeometry('POLYGON(EMPTY)')
>>> print g.wkt, g.hex
Ticket URL: <http://trac.osgeo.org/geos/ticket/594>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
