[geos-devel] [GEOS] #585: mingw64 trunk make check fail on badthreadtest
geos-trac at osgeo.org
Sun Sep 30 11:30:05 PDT 2012
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: closed
Priority: minor | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution: invalid
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => invalid
Comment:
Nevermind. The fundamental problem is that the platform.h.in is all wrong
for 64-bit builds, but more or less right for 32-bit builds.
I discovered why my windows 7 box was exhibiting different failures.
In my jenkins install, I had hacked the platform.h.in to work for mingw64
bit using the hack:
http://www.gaia-gis.it/spatialite-3.0.0-BETA/mingw64_how_to.html#libgeos
, but it caused issues for 32-bit evidentally causing it to go thru this
badthreadtest loop. So short answer your platform thingy doesn't work and
I have to have a different one for 32 vs. 64 bit.
Ticket URL: <http://trac.osgeo.org/geos/ticket/585#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
