[geos-devel] Gsoc 2013
vishal tiwari
hi.vishal123 at gmail.com
Tue Apr 2 10:59:58 PDT 2013
Hey,
I have some doubts. I see that there is only one class that is,
VoronoiDiagramBuilder that is required for the voronoi class. And what is
the purpose of the other class, as i don't see them inside the code of the
VoronoiDiagramBuilder class. The classes that is needed in
VoronoiDiagramBuilder class are already ported. I think the rest of the
class correspond to Conforming Delauny triangulation. So i need to know
what all needs to be ported as the part of the gsoc project?
Today i was trying to port the VoronoiDiagramBuilder.java class. and while
porting i noticed that a method
DelaunayTriangulationBuilder::unique(DelaunayTriangulationBuilder::unique)
is of type "void".
But the corresponding method in DelaunayTriangulationBuilder.java in JTS
returns a CoordinateList. I want to know is it some error, or i am going
wrong?
I made the VoronoiDiagramBuilder.h file, was thinking if you could just
give it a look(attached to the mail). I have written some part of the .cpp
file as well, before i got suck in the problem.
Thanks,
On 2 April 2013 01:32, Sandro Santilli <strk at keybit.net> wrote:
> On Sun, Mar 31, 2013 at 01:05:30PM +0530, vishal tiwari wrote:
> > Hey,
> > I found the code, it wasn't there with the initial search result on git.
> :P
> > Now i understand what you mean by what was missing. I can see a bunch of
> > files that are not in triangulation, so i suppose the project is to write
> > these missing files, which correspond to the Voronoi diagram generation.
> > Tell me if i am going wrong.
> Sounds correct :)
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Vishal Tiwari
Undergraduate
Computer Science and Engineering
Lab for Spatial Informatics
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130402/fdaccf69/attachment.html>
Type: text/x-chdr
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130402/fdaccf69/attachment.h>
