[geos-devel] geos_svn_revision.h and cmake
David Burken
dburken at comcast.net
Sat Aug 3 10:30:50 PDT 2013
On 8/3/2013 12:36 PM, Mateusz Loskot wrote:
> On 3 August 2013 16:31, David Burken <dburken at comcast.net> wrote:
>> On 8/3/2013 10:42 AM, Mateusz Loskot wrote:
>>> On 3 August 2013 15:17, David Burken <dburken at comcast.net> wrote:
>>>> All,
>>>> I have a patch to auto generate the geos_svn_revision.h. After fixing my
>>>> error, I wasn't sure if I should submit a ticket after reading the below
>>>> links? If you want it, I can do a ticket. I
>>> David,
>>> Please, submit your contributions, they're hugely welcome!
>>> I'll try to test them and commit.
>>> Best regards,
>> Done:
>> http://trac.osgeo.org/geos/ticket/643
> Committed.
> r
> I'll be testing some corner cases later.
> Thanks!
> Best regards,
Hey I think you forgot to commit a file:
-- Found Subversion: C:/Program Files/TortoiseSVN/bin/svn.exe (found
version "1.8.1")
CMake Error: File
D:/dev/vs11_x64/geos/geos-svn/tools/geos_svn_revision_cmake.h.in does
not exist.
CMake Error at CMakeLists.txt:260 (configure_file):
configure_file Problem configuring file
