[geos-devel] [GEOS] #588: [JTS fixed] valid polygon when cw, not valid when ccw
GEOS geos-trac at osgeo.org
Sun Aug 4 15:32:16 PDT 2013
 Reporter:  olivier80   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.5.0
Component:  Default     |     Version:  3.3.5
 Severity:  Unassigned  |    Keywords:  jtsfail
Changes (by robe):
  * milestone:  3.3.9 => 3.5.0
Comment:
 this sounds complicated and trying to do something in a micro that affects
 all intersection matrix calculations sounds a bit scary to me.  Push
Ticket URL: <http://trac.osgeo.org/geos/ticket/588#comment:9>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
