[geos-devel] [GEOS] #648: Change svn/git line breaks to Unix
geos-trac at osgeo.org
Sun Aug 11 14:05:47 PDT 2013
Reporter: robe | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: minor | Milestone: 3.5.0
Component: Default | Version: 3.4.0
Severity: Unassigned | Keywords:
Comment(by robe):
Mike,
thanks for the input. No rush on change since next at best will be 3.4.1
or 3.5. That would be very helpful if you can come up with SVN properties.
I think we have such for PostGIS so it for example doesn't fiddle with the
sql files.
On note of Tortoise, maybe it does. Haven't looked. I've been using the
svn and git of late with the latest msys since that provides me a single
install with everything Posix I can tag along on my usb stick and enjoy
the Open source offerings I've grown accustom to. Those are both
commandline only and haven't looked to see what switches they provide. I
presume they provide the same switches as what the Unix/Linux ones have.
Ticket URL: <http://trac.osgeo.org/geos/ticket/648#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
