[geos-devel] [GEOS] #649: ST_Snap crashes on some inputs
GEOS geos-trac at osgeo.org
Fri Aug 16 07:36:28 PDT 2013
 Reporter:  robe        |        Owner:  geos-devel@…
     Type:  defect      |       Status:  reopened
 Priority:  major       |    Milestone:  3.4.1
Component:  Default     |      Version:  3.4.0
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment(by strk):
 Bingo, the actual offending input is:
 A: LINESTRING(-71.1317 42.2511,-71.1317 42.251,-71.1317 42.2509)
 B: MULTIPOINT(-71.1261 42.2703,-71.1257 42.2703,-71.1261 42.2702)
 Assertion failing:
 snap/LineStringSnapper.cpp:349: void
 geos::operation::overlay::snap::LineStringSnapper::snapSegments(geos::geom::CoordinateList&,
 const ConstVect&): Assertion `pf != 0.0' failed.
Ticket URL: <http://trac.osgeo.org/geos/ticket/649#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
