[geos-devel] 3.4.1, stray patch from pkgsrc
Paragon Corporation lr at pcorp.us
Mon Aug 19 18:43:43 PDT 2013
 strk,
You have any issue applying the #650 patch.  I can do it and test on my
different systems if it looks okay to you.
Thanks,
Regina
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Greg Troxel
Sent: Monday, August 19, 2013 8:27 PM
To: Sandro Santilli
Cc: GEOS Development List
Subject: Re: [geos-devel] 3.4.1, stray patch from pkgsrc
Sandro Santilli <strk at keybit.net> writes:
> On Sat, Aug 17, 2013 at 09:09:31PM -0400, Greg Troxel wrote:
>> pkgsrc is carrying the following patch.  It strikes me that probably
>> there should be a configure-time feature test instead.
> Indeed configure is already checking for isnan, but the block you see,
> full of OS checks, is run when HAVE_ISNAN is undefined.
> The correct fix would indeed be with defining a possibly different
> macro for HAVE_STD_ISNAN or fix the configure test to use full
> qualification when trying.
> I'll love to see that ugly block in platform.h removed, but I'm afraid
> we don't have a large enough set of builders to catch a bug as soon as
> it is introduced. If you have a patch for configure that fixes the
> *BSD case I'm happy to apply it.
http://trac.osgeo.org/geos/ticket/650
And for the larger isnan issue:
http://trac.osgeo.org/geos/ticket/651
>From reading the g++ headers, it seems that it's wrong to use bare isnan in
C++.  But I could well be misinterpreting that.
