[geos-devel] [GEOS] #652: 32-bit regression failures
GEOS geos-trac at osgeo.org
Tue Aug 20 05:30:05 PDT 2013
 Reporter:  mwtoews     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:  32-bit
Comment(by strk):
 Can you check if the query in
 http://trac.osgeo.org/geos/ticket/527#comment:3 gives you any record in
 output ? Absence of any record means that the output from ST_UnaryUnion is
 correctly noded, and that's what the test for #527 is about.
Ticket URL: <http://trac.osgeo.org/geos/ticket/652#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
