[geos-devel] [GEOS] #652: 32-bit regression failures
GEOS geos-trac at osgeo.org
Tue Aug 20 13:05:49 PDT 2013
 Reporter:  mwtoews     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.5.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:  32-bit
Comment(by mwtoews):
 Replying to [comment:1 strk]:
 > Can you check if the query in
 http://trac.osgeo.org/geos/ticket/527#comment:3 gives you any record in
 output ? Absence of any record means that the output from ST_UnaryUnion is
 correctly noded, and that's what the test for #527 is about.
 There were 0 rows from the query with 32-bit Ubuntu 13.04, POSTGIS="2.1.0
 r11822" GEOS="3.4.1-CAPI-1.8.0 r3892" ...
Ticket URL: <http://trac.osgeo.org/geos/ticket/652#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
