[geos-devel] [GEOS] #658: Add 32bit build in travis-ci config
GEOS geos-trac at osgeo.org
Thu Aug 22 01:56:46 PDT 2013
 Reporter:  strk         |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  GEOS Future
Component:  Default      |     Version:  3.4.0
 Severity:  Unassigned   |    Keywords:
 I understand the current travis setup is building using CMake and Automake
 with both GCC and clang, but only as 64bit. If that's correct it would be
 nice to add a 32bit build to the matrix.
Ticket URL: <http://trac.osgeo.org/geos/ticket/658>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
