[geos-devel] Compiling geos with mingw64
David Burken
dburken at comcast.net
Fri Feb 15 06:48:59 PST 2013
I'm attempting a 64 bit windows build with the mingw cross compiler on
linux. Here's my hacks to get geos to compile if anyone's interested.
See below.
Take care,
Dave
// My cmake script:
#!/bin/sh
# File: geos-cmake-config.sh
build_dir="/work/mingw"
mingw64-cmake -G "Unix Makefiles" \
-DGNU_HOST=x86_64-w64-mingw32 \
-DCMAKE_C_COMPILER=/usr/bin/x86_64-w64-mingw32-gcc \
-DCMAKE_CXX_COMPILER=/usr/bin/x86_64-w64-mingw32-g++ \
-DCMAKE_BUILD_TYPE=Release \
-DCMAKE_INSTALL_PREFIX=${build_dir}/sandbox \
-DCMAKE_MODULE_PATH=${build_dir}/geos/geos-svn/cmake/modules \
../geos-svn
// Files touched:
$ svn status
? geos_svn_revision.h
M include/geos/inline.h
M include/geos/platform.h.cmake
M include/geos/profiler.h
M include/geos/timeval.h
// Fixe "multiple defines" in dot.inl files:
$ svn diff include/geos/inline.h
Index: include/geos/inline.h
--- include/geos/inline.h (revision 3765)
+++ include/geos/inline.h (working copy)
@@ -18,7 +18,7 @@
#ifdef GEOS_INLINE
# define INLINE inline
#else
-# define INLINE
+# define INLINE inline
#endif
// isnan is in std namespace (hack):
$ svn diff include/geos/platform.h.cmake
Index: include/geos/platform.h.cmake
--- include/geos/platform.h.cmake (revision 3765)
+++ include/geos/platform.h.cmake (working copy)
@@ -123,6 +123,7 @@
# endif
#endif
+#define HAVE_STD_ISNAN 1
#if defined(HAVE_STD_ISNAN)
# define ISNAN(x) (std::isnan)(x)
#elif defined(HAVE_INLINE_ISNAND_XCODE)
// No config.h and gettimeofday call is ambiguous:
$ svn diff include/geos/profiler.h
Index: include/geos/profiler.h
--- include/geos/profiler.h (revision 3765)
+++ include/geos/profiler.h (working copy)
@@ -20,7 +20,7 @@
/* For MingW builds with __STRICT_ANSI__ (-ansi) */
#if defined(__MINGW32__)
/* Allow us to check for presence of gettimeofday in MingW */
-#include <config.h>
+// #include <config.h>
#include <sys/time.h>
extern "C" {
@@ -71,13 +71,13 @@
/** \brief start a new timer */
void start() {
- gettimeofday(&starttime, NULL);
+ gettimeofday(&starttime, (void*)NULL);
/** \brief stop current timer */
void stop()
- gettimeofday(&stoptime, NULL);
+ gettimeofday(&stoptime, (void*)NULL);
double elapsed = 1000000*(stoptime.tv_sec-starttime.tv_sec)+
(stoptime.tv_usec-starttime.tv_usec);
// timezone struct defined in time.h
$ svn diff include/geos/timeval.h
Index: include/geos/timeval.h
--- include/geos/timeval.h (revision 3765)
+++ include/geos/timeval.h (working copy)
@@ -31,10 +31,12 @@
#define EPOCHFILETIME (116444736000000000LL)
#endif
+#if 0 /* tmp drb */
struct timezone {
int tz_minuteswest; /* minutes W of Greenwich */
int tz_dsttime; /* type of dst correction */
+#endif
